Rigid Inflatable Boats
Discussion in 'All Things Boats & Boating' started by kach22i, Oct 30, 2005.
  1. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    I'm seeking to better understand the advantages and disadvantages of RIB designs.
    How do they work?
    Here is a typical claim:
    http://www.e-inflatableboats.com/Rigid_Inflatable_Boats.html
    Wave impact absorption
    Stable
    Buoyancy
    The list goes on, however I can't seem to find a lot of actual testing or concept engineering on-line.
    What I'd like to read about is how the design specifics of RIB design have been developed over the years.
    What are the typical standards?
    That is to say, what air pressure is best and why?
    What's up with the closed cell foam filled boats, what do they gain, what have they given up?
    How hard is too hard (air or foam)?
    How soft is too soft (air or foam)?
    Aside Note: I own a hovercraft, and may seek to make a connection regarding wave impact. In the hovercraft, the least resistance may often be best (long story), in a RIB I have no idea how the air spring rate is established, what typical pressures are, and why.
    EDIT: Please provide links to good articles, that would be a good starting point for me.
  2. kach22i
    kach22i Architect
    More on the foam stuff:
    http://www.special-operations-technology.com/article.cfm?DocID=607
  3. cyclops
    cyclops Senior Member
    Can you imagine how much space is taken up by the internal and external foam collar? Rough water ride is none existant because they " sneak in ". Do not expect this boat to compete with standard boat designs. Do you NEED a bullet proof boat on your cruises? A very special boat design for a very special need.
  4. kach22i
    kach22i Architect
    Yep, and "roostertails" can show up on surface radar, which is why waterjets are popular on the larger ones (plus stopping/turning ability).
    Ride is unimportant in the military craft - a given.
    So maybe there is a new question here? Does one automaticly give up "stability" for ride comfort?
  5. kach22i
    kach22i Architect
    On the smaller craft, they appear to be laying down on the sponsons, equal number of guys on each side.
  6. jfblouin
    Likes: 1, Points: 0, Legacy Rep: 24
    jfblouin Senior Member
    RIB have somes advantages:
    - low weight (need less HP for same speed or go faster with same HP) easier to move with trailer
    - low free board (helpfull for diving operation) and give a good near to water feeling.
    - boat to boat impact proof (you can put your boat side by side with another boat without dammage)
    -good seaworthy with big reserve of stability and flotability (a safer boat lenght for lenght)
    - sport ride (like motorbike)
    RIB have some disadvantages:
    - high cost (you get small boat space and no convinience at high cost)
    - need high maintenance on rubber collar (many glue job each year)
    - give wet ride
    - small usable boat space for same size boat
    You have to choice a boat for your requirements
  7. kach22i
    kach22i Architect
    That's as far as I ever get on the topic. I'm looking for more information such as:
    1. Air Pressure
    A: How much is too much?
    B. How much is too little?
    C. Why is there such a thing as too little?
    D: Test data - give me some.
    2. Foam filled version
    a: Advantage over pure air
    B: Disadvantage over pure air
    C: Test data - give me some.
  8. kach22i
    kach22i Architect
    Odd Find:
    Foam boat, kiddie style...............................
    ...............and for my next great idea, the Nerf car, although I think "Saturday Night Live" did that one already. They did the Chia pet car and Adobe car, right?
    Showing my age.;)
  9. cyclops
    You will have to contact each boat company to get answers to your questions.
  10. jfblouin
    The average pressure is 3.5 psi.
    Too much pressure cause high stresse on joints
    Too less pressure raise the fabric wearing and risk of pinching the fabric when you hit a solid object
    Foam collar are puncture safe but weighty.
  11. kach22i
    kach22i Architect
    That information helps a lot, thanks.
    Here is what a guy (Barry Palmer of Sevtec) said, who once build a hovercraft using inflatable sponsons.
    http://groups.google.com/group/alt....c7033/e9aefaf70042297e?hl=en#e9aefaf70042297e
    I think he used half the pressure, because the hovecraft is not in constant contact with the water, and the weight of the craft is not bearing on it in standard (hover) operation.
  12. cyclops
    The only similar thing about the 2 different craft is the air pressure.
  13. kach22i
    kach22i Architect
    I've owned both, a hovercraft off cushion is like a bad raft. Also I've had waves break the bow of the hovercraft, followed by a wall of water flying over my head and smack my spinning fan blades with a frightening sound.
    I really don't like waves washing away my skirt pressure/cushion and making part of the craft a boat in displacement mode - no offense to the many boater's here - I prefer to fly, even if it's only six inches above the surface.;)
    I think in a very heavy sea state they might react more a like than not. Although common sense prevents me from testing this theory in field at the moment.
  14. cyclops
    That is a problem when the skirt is all 1 chamber. The military has several chambers to elimanate those problems. Money is no problem.
  15. kach22i
    kach22i Architect
    True, but in addition to multi-chambers (Sevtec has them on small craft) the large size helps and more importantly the length helps.
    Small craft:
    Lets say a 1-meter high wave forms and crests in front of a 2-meter long craft (hover height 15mm/6 inches) - it will take out most of the cushion as it passes below.
    Large Craft:
    Now imagine a much larger military LCAC encountering 2.5-meter high waves which form and recede in the craft's path. The LCAC is around 30 meters long (100 feet) and has a cushion height of 7 feet/2-meters. Proportionally the waves are smaller than the small craft example, but perhaps even more important is the wave will crest and recede within the length of the craft, making bisecting cushion dividers useful.
    Back to RIB's:
    I guess what I'm trying to get my mind around is that a hovercraft "off-cushion" in heavy seas is dangerous, as the craft may flip over. The hovercraft has lots of buoyancy just like a RIB, and a flat-ish bottom like most of the RIB's. So how can the RIB's have any claim to stablity in heavy seas?
    It it just the fact that you keep moving despite being tossed about and swamped with water coming in?
    EDIT:
    Here is another way of dividing up hover chambers (from Spain):
    http://www.neumar.com/Research.htm
