High-Speed Waveless Sinusoid Propeller
Discussion in 'Boat Design' started by waveless, Aug 7, 2005.
  1. waveless
    waveless Junior Member
    Have you ever saw this kind Propeller?
    How it works?
    What do you think about it?
  2. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    cant say i have
    can only imagine vertical waves now ( but havent given it a real deep thought )
    why mounted at the stern of a so called waveless boat design missing a front prop?
    should this not be posted at modern paddlewheels or under the propulsion threads?
    must say its inventive :D
  3. JonathanCole
    Likes: 10, Points: 18, Legacy Rep: 58
    JonathanCole imagineer
    This device works by the viscosity of laminar flow which is increased by the weight of water falling into the v between the 2 wheels. Actually a Tesla turbine might be a better way to use laminar flow as a propulsion medium. Does it have a pass through tube from the front?
    But if the disks are solid at those angles, maybe the boat would pivot around the bow!
  4. waveless
    There are not 2 wheels, that's 2 flexible lamina. It is suitable for twin-hull boats that Sinusoid Propeller can put into front or middle of the boat.
